I have a 500hp stroker in my 68 Charger with a 4 speed and it has a 8 3/4 rear in it no problem. It has 3.91 gears in it as well. It all depends if your running street tires or slicks. If you have street tires and no traction nothing breaks usually just smokes the tires like mine. if you start doing trans brake/clutch drops and have slicks, then you have a bigger issue to deal with and should probably go Dana. For a street car with little traction and burnout machine the 8 3/4 will hold up fine.
