Hi Ed, I am a bit late to your thread on this subject. I was also doing my brakes at about the same time you were doing yours. Mine is power drum system that is the size as yours and when I finished everything was fine for a short time and then I noticed it started pulling to the left. Like you, I have done many manual adjustments to the front brakes to get them to slightly drag the same amount and I always find that the left wheel will be spinning freely, while the right wheel will have the same amount of drag I adjusted it to.
Any chance that you witnessed that in your findings. I know you waiting to see if a different sway bar was the problem. Thanks, Ray
Hey Ray,
Yes sir, now that you mention it - it was as if the new self-adjusting hardware was backing off or something.
Never did find a logical explanation for it, must be beyond my mechanical comprehension I guess.
I wound up totally removing the self-adjusting hardware from the fronts and installing manual stuff, which
really didn't solve much either.
There HAS been a bit of an unexpected update on the situation, however:
As I had resigned myself to doing the usual disc conversion, something else started to occur as I drove Fred:
Fluid started "disappearing" from the master cylinder, ever so slowly...
Despite my looking for leaks under the car, inside the drums, the usual places, I came up empty at first.
Then it finally occured to me - the master cylinder itself, which was new when I bought Fred (and therefore,
had next to no miles on it) is apparently the "leakee" I believe.
As it's very difficult for me to maneuver under the dash these days, I haven't gotten under there to see what's
what, but I can almost smell the fluid when I'm driving Fred now.
It only makes sense - the very last thing on the system, the one I hadn't touched in my rebuild efforts, may
turn out to have been the culprit all along.
