Is it Ok to mount before the distribution block? I was told it could set off the warning light when the pressure is decreased.
if it is for the rear brakes, it should be after the distribution block.
That's how mine is done. No distribution block,According to Rick Ehrenberg all that distribution block **** can be discarded. Plumb the rear brakes directly to the proper master cylinder reservoir using a Y on the rear end. Plump the fronts directly to the appropriate rusing a T. Plump the prop valve anywhere in the rear line. In its current state, the brake warning light will only come on when you have no brakes - presumeably you won't need a light to tell you that !!
They're needed in my case due to rhe pistonGet rid of the residual check valves - not required with disc and were only needed on old style drum cylinders.
That is where you want it. You do not want it between the master and valve as shown in your photo.
You want it past any proportioning or distribution points. Once there it can do its job correctly as far as adjustable pressure control to the two rear brakes.I will ask why it has to be mounted after the block? I am doing a front disk conversion on my 64 Fury. It has a updated dual master cylinder distribution block with no proportioning valve and I will be using the adjustable valve for the rear brakes. The distribution block is mounted on the frame rail in its original position.
Didn’t mean to step on your post but it seems silly to start another to ask one question.
So the adjustable valve goes between the block and the rear flex hose.It’s a 64 Fury, there is no valve in the brake line and just a solid brass dual port block that changes the direction of the fluid.
All I can tell you is what I was always told and have done. The adjustable valve goes after any proportioning or distribution points. Without seeing your cars brake configuration it is hard to tell you anything else. The valve is a control. You want it set up so the pressure you are trying to control inputs the valve. The output goes directly to what you are trying to control. So on the valves output you do not want the fluid going anywhere else. You want it going to the rear wheels in your case.Thanks for your response and I respect your knowledge but you still haven’t given a mechanical reason why it can’t be done. Later cars had the distribution blocks on the inner fender well which made it easy to do what you recommend but I won’t mount a valve that can be damaged outside a protected area. Thanks again!
64’s DO NOT have a proportioning valve
