charger318
So I have a question I was hoping someone could answer. I have been looking into using 273 adjustable rockers with a hydraulic cam. from what I have read you adjust them much like a solid lifter cam with the lifter on the heel of the lobe until you get to zero lash, and then you preload it to .020-.060.........and all of this is done with the lifters being empty of oil, so not primed. but if u go to zero lash and then preload it to .030 lets say what happens when u start the engine and they want to pump up? you already adjusted the push rod down with them collapsed all the way? just trying to get more info before I finish putting the old 318 back together this spring. thanx
