gtxrt
on a stock, say 1969 440 when is the distributor advance all in by.
thanks all for the replies. wasn't going to recurve, didn,t want for it to ping, but i sent it out for a conservative curve. something like 12* initial and all in by 3200 rpms, what do you think ?
yes stock no porting 915 heads. 217-221 on a 110 LSA comp camsby stock, you mean iron heads, factory cam set up as original ?
First, if you're going to play the Mopar game learn the correct names. "Posi" is a GM name, and most Mopar people will laugh at you for using it, we have "Suregrip" limited slip diffs.Hughes 2000 stall, 2.94 posi with a small one size over stock cam. 3900 lbs. what am concerned about is 9.5 compression with iron heads.
