Does anyone have a good part# for air shocks for a '67 Bellevedere.
While this is true, even without bearing weight the shock mounts still have to absorb upward and downward loads that in effect still look the same as weight to the carrying part. Putting a shock onto a shock dyno can show hundreds of pounds of force exerted on the ends while traveling over road bumps and uneven surfaces. It only takes a couple hundred pounds of push from an air shock to make a difference in ride height, (divided by two shocks) and this could easily be compared to the extra loads that you'd get by putting on a set of extra firm conventional shocks.Shocks are not meant (meaning: designed/engineered) to handle weight at all.
Their purpose on any suspension is to dampen vertical movements of the suspension.
As such, Ma Mopar did NOT incorporate into their chassis design the provision for the shock mounting points
to bear actual vehicle weight.
Me too......I've used them on all three of my Coronets....but, I don't pound on them...or corner....lolFrom personal experience, I've used air shocks in several different cars since 1972, installed them in customers cars ( including station wagons ! ), and have known others with air shocks in their cars. And never, not once, have I've seen a shock mount break. Ever.
......oh, I feel it. Car is very sensitive......but, no I'll make sure its toughGet underneath your car and have a look at the upper shock mount - touch it, feel it, wiggle it then use your head and figure out what's the right move.
