Alternator charging problem
stanz
9:22 AM
TEXAS
Recently upgraded my 68 Roadrunner for electronic system and replaced wiring harness, but I am having problems with the charging fluxuating with RPM's I mounted a new VR QS 8313 and replaced alternator with a Duralast DL75334 to increase amps, but cannot get it to stay steady. I was wondering how to make sure wiring is connected correctly, blue wire to positive side brush fld clip and green wire to the ground side fld clip? HUMMMMMM
Both field terminals need to be isolated from ground with the solid state regulator you're using.
If they weren't he'd probably have smoked his harness already, but worth sticking a meter on to make sure...
It actually doesn't matter if they are both isolated from the case.
But why does my voltage still goes up and down with my RPM's up to 13.5 when I raise over 2000 and 10 volts at idle 800 or so RPM's
Do you have any big current draw items?
13.5v is pretty normal but 10v is low even at idle.
The alternator just can't produce enough for some reason. I'd be okay with 12.5-13.0 at idle.
You have a fully charged good battery?
Battery fully charged that's what's the alternator output
If you're hooked to a good, fully charged battery... alternator is properly wired to said battery... there is no way you can read 10 volts unless you're running a LOT of electrical equipment you shouldn't be. As for the idle to higher rpm increase in output, that's how they work. Now there is a chance you have a bad diode in that alternator...
What is the battery voltage with the car completely off? Should be around 12.7v
There was a bad diode but I replaced the alternator and ran a test with a good one but still got the same results so I thought I might have the connector on backwards but have not tried with wiring switched
As mentioned, nothing will change (or shouldn’t at least) switching field terminals wires on an isolated brushes alt setup
Stock type alternators don't put out alot of current at idle.
You would need the output vs. RPM graph to really know how much current you get at low RPM.
If you have an underdrive crank pulley it will make things worse. Part of the equation is knowing the crank to alternator pulley ratio.
If you suspect a wiring problem, make sure you have full voltage at the blue wire. It should be the same as battery voltage, but might be slightly less because of ignition switch and connection resistances. If you ground the terminal the green wire is on, that will apply full field current and the alternator will output is maximum current for the RPM is is spinning.
If your charge voltage is still too low at idle, with full field current, then you either need to change the pully sizes to increase alternator RPM, or get an alternator with better low RPM output, or just live with it and try not to idle alot. Make sure to remove the ground from the field and re-attach the voltage regulator wire.
If the ground wire test above did provide good alternator output, then your regulator might have a bad ground from the case to the firewall and engine block.
It is always a good idea to run a ground wire from the back of the cylinder head to the regulator / firewall.
Case is grounded to firewall and engine block. What I am confused about is the alternator wiring which is correct
There is a very simple way to wire in a dual field alt on the 69 and older cars. I don’t have any pics right now as my car is in storage. I can walk anybody thru it in less than a minute. I’ve been doing it this way since the early 80s. Message me if u would like to know. Kim
Maybe this?
I made a colored version of this diagram LOOOONG time ago, and was posted and reposted since that on several boards… but this is the one I found on line at this moment
