Hemirunner
How do you install these little window corners??
I'm assuming they go on underneath the quarter panel like so??
If that's the case, do you trim out the area in the AMD quarter panel so they blend together into the corner area?? You can see that the little 'pocket' in the AMD quarter is directly over the little 'pocket' in the patch piece. Do I cut that area out on the AMD quarter panel?
You can see that without them, there's a huge gap.
Anyone have some photos of how they installed these??
