Ammeter Bypass question
70rr-brian
5:18 PM
Florence, KY
70 roadrunner....
If I run an 8 gauge wire from the alt (batt post) to the starter relay (batt post) with a 12 gauge 30 amp fusible link. Then another 8 gauge wire from the starter relay (batt post) to the positive battery terminal again with a 12 gauge 30 amp fusible link I should be good?
This large wire will render the existing ammeter loop useless since the electricity will take the path of least resistance?
Thanks
Don't to trace the wires through the firewall to the amp meter. You can connect the wires and take the amp meter totally out of the loop.
Yeah that's how it is now... I was just trying to cut down as much as possible flowing through the bulkhead.
