Another Car Lift idea
I saw this lifting idea at Carlisle. It is called QuickJack. I have no need for it as I have a full size two post lift, but I like this design a little bit better then the one above.
The web site is here: https://www.quickjack.com/
This seemed to be a pretty good review on the jack: http://oppositelock.kinja.com/tool-review-the-quickjack-is-it-as-good-as-a-real-li-1796401355
Note: I have no connection with either brand, and I have not used either - just offering folks another similar alternative for consideration.
Hawk
...........It is called QuickJack.......
Lol, did they say "Quick"? Not sure about "quick", especially with FW's, but it works....
How are they for side to side motion? stable?
Mine's a 5K lift, 110V, and works well in a low ceiling garage. A little heavy but it is "portable".
Even with the "skimpy" stacked rubber blocks it feels fine. One day I'll make a solid riser set to use just the shorter rubber block. I wouldn't have a problem pulling a trans under it. There is nothing between the two sides to interfere with jacks or roller carts.
A longer version (which a "B" would need IMO), 7K lift is available now I guess.
Read a lot of reviews and they seem to center on leaking connections and pump failure.
Just my opinion but isn't that no better than jackstands other than being faster? I don't want to crawl around anymore lol.
I would recommend anybody thinking about buying a lift of any type to do your homework, I've seen video's of cheap lifts buckling before ever reaching their capacity.
