Another intake thread
The engine builder and head porter both told me that I'm leaving about 30 hp on the table by not using the RPM, but the look is more important to me.
This is where I’m at. Look is more important. I was hoping to keep the dual snorkel, I would switch the intake only if I could keep the dual snorkel. If there is not much difference between the stock 71 and an aftermarket I’m keeping the stock one. I’m not drag racing. A few tenths of a second and mph ain’t gonna kill me.
so what was the difference when you went to the 71 intake from the Torker. lost top end power ? better throttle response ?
No seat of the pants difference, and it was a Torker 2 I took off. I don’t know what the motor was making because I didn’t build it. Definitely heads cam intake exhaust but not sure specs. The car is currently under restoration so the motor is going to be torn down and rebuilt too. Hence this thread as I’m planning on what that’s going to look like.
I would guess the porting helped 15 HP on the ch4b plus an alum intake is a lot easier to port than a stock iron intake.
Bill told me 10-15 which is fine by me. He also said that I spoiled him because he's used to porting the iron manifolds and the aluminum intakes are like porting a stick of butter...lol
Why does it matter in the context of this thread? The OP has hood clearance issues and and cannot figure out how to make the air cleaner work with any tall intake. So with that my position is simply that he can use either the Performer, or CH4B, and turn his 600 hp motor into a 475-500 hp engine instead of a 400-425 hp engine.
Thank you for keeping on topic. Not sure I would lose 100 hp though. More like 30-50 was what I was thinking. And that’s probably going to be at the high rpm range which I’m not drag racing so it really doesn’t matter because the car will rarely see high ends of RPM.
must be more than 300 HP to go 14 seconds and 100 mph with a roadrunner. stock roadrunners were around 15.5 seconds 1/4 mile times.
That’s exactly what I ran in 81 with my motor and best of 15.01 but had 4.56 gears and basicly all stock
That’s the article but it used to have a chart at the end comparing them all. It doesn’t say what the gains were from each one. And the iron intake they used is not the premium one I have.
I’ll be watching this thread to see the requested results for hp numbers on the dyno vs rear wheels
So now I’m confused. You stated you wanted to build a 700-800 ho motor and building it around the dual snorkel air cleaner? Sounds like a lotta hp for a street car but like I’ve stated will be watching the dyno and rear wheel hp numbers. With my 70 air grabber car this might be my street/strip set up on a 3400lb car
everything posted on here was on topic. you asked how to use the stock air cleaner and was told how. you asked about different intakes and also were told. after 1967 all the intakes were no different and the 71 intake is no prize even though you think so. you're going to lose closer to 75 HP with a stock intake plus the stock air cleaner.
I would just use a 1967 dual snorkel with a 400 decal they look a lot cleaner and better looking than the 74. anyways I would get the Edelbrock drop base for the bottom. and get another 74 air cleaner not having to be that nice of a condition cutting the complete bottom out around the outer edge. I would permanently attach the lid to the top of your air cleaner to the sides so it could not come off. the K&N filter would rest on the top of the drop base. the air cleaner which is now just the sides and top as one piece like the 67 air cleaners would rest on top of the air filter. the bottom of the air cleaner will have about a 1/2 inch opening going all around the bottom like the unsilenced 1968 air cleaners for more air. would it work idk would I try yes I would just because nobody did it before.
67 is to period dated. I would rather use a 70s. This is a good idea now if I can find a 70s style to experiment on. Problem is they aren’t cheap in any condition. I paid $400 for mine.
So excited. Looks like I have a premium intake. :)
Sorry, couldn’t resist.
Apples to Oranges
Little easier as far as height with a 383
383/432 Stroker
Weiand Dual Plane
I also told myself - Factory 1971 Dual Snorkel Air Cleaner is a must - I also have the luxury of using a much taller WIX air filter
I modified a Fel Pro bathtub so I could just swap DUAL PLANE intake manifolds using those silicone Hughes intake paper gaskets - Simple and effective
This on the street
3:91 Sure Grip
Like mentioned , the Weiand dual plane is great off idle , I mentioned the taller air filter , accepts the factory one piece kick down linkage for 1971 - However it just chokes the motor after 5,000 RPMS , especially on the highway
I installed a Edelbrock RPM dual plane that I borrowed for a few days
Was night day difference above 4,500 RPM all the way to 6,000 RPM if needed on the highway
Honestly felt like a different motor
Problem was the added 1.5" intake manifold height - So I dropped the air filter down - Now I never really checked hood clearance with clay or tinfoil if I was to use the taller air filter with the factory dual snorkel
My biggest issue was the 1971 factory ONE PIECE kick down linkage and rod for the AUTO Transmission and the Edelbrock Carb running the RPM Intake Manifold
Anyways a future project
I hope to not sound jerkish, but I think the OP is overthinking this. If the car is apart at this moment, nothing can be certain until it is reassembled. If I can fit a Torker/750 DP/dual snorkel B motor combo under the hood of a 73 RR ,then surely an RB with a minimal amount of K member shimming and /or air cleaner base plate modification, intake carb pad milling, etc would fit. I just snapped some pics. No evidence of the housing ever contacting the hood. If I had some modeling clay I would measure the distance between the housing and the hood, but I don't have any. My air cleaner is off a 71 RR. I don't know if there is a difference. Personally, there is no way in hell i would put a stock intake on a 600 hp engine. Horsepower costs enough as it is without handicapping yourself with such a simple piece. Please forgive the dreadfulness of my engine bay. The outside of the car is even worse.
Apples to Oranges
383/432 Stroker
Weiand Dual Plane
This on the street
3:91 Sure Grip
Did you cut the ports off the pan gasket and RTV it under the head?
Yep
It’s already been together with the torker 2 and the dual snorkel doesn’t fit. The dual snorkel just fits with the stock manifold. The dual snorkel added an inch.
That is correct - Cut the ports off , with leaving enough material - Measure 100 times - Anyways for a little extra strength , I wanted to bend the sides of the bathtub down on both sides towards the Edelbrock heads ever so slightly to make the bathtub rigid and strong
Using our metal bending brake at work , I couldn’t believe how tight and perfect I got the bends the first time around to match up with the heads
Very very little silicone on top - Maybe a 1/16" on each side
Beautiful. I’ll be doing that next. Honestly, you could sell that.
