- 11:28 PM
- Jun 16, 2008
- In Absentia Texas
Ok....I'm still working on my Duster.....yes....a lowly A body, but it will bee a good car when I'm done.
Anyway, today I carted my seats off to have the new covers put on (restuffing required otherwise I would have done them) and I started installing working on installing the factory seat belts.
"Welcome to another edition of......WHAT WERE THEY THINKING?"
The car had aftermarket belts in it and the "outside" belt was secured to the bottom of the seat, sandwiched between the seat base and seat track.
So I pull the carpet back to locate the factory mounting hole........and can't find it. But after removing some black crap from the floor (here comes the good part) I found the original bolt.....still screwed in the hole.......and CUT OFF! Yes, what were they thinking
Well after some cursing, drilling, pounding, and judicious use of an ancient easy out from my late father's tool box I got the bolt (on the driver's side) out. :HappyNewYear:
But now I have a question. The two center belts are also set up for a center belt. So the question is, "does the belt with two buckles go on the driver's side of the hump, or on the passenger's? This is relating to a 72 era A body
Thanks much
Thanks much
