Any benefit to a tubular K-frame that retains T-bars ?
ardentind
3:24 AM
Idaho
I have the K-member out of my '67 Belvedere. Its been blasted and I had planned to seam weld it and reinforce it.
Its ugly, ridiculously heavy, etc. I'd like to keep the torsion bar setup but keep thinking of how easy it may be to replicate the factory K-member in a tubular style, but that retains factory steering box mount, idler arm mount, and torsion bar mounts.
Less weight, a lot more room up front...any other benefits that anyone could see? I've yet to have a motor in this car so I cant really judge how tight things are in certain situations.
I know plenty of people will argue its not worth it, "Why?", etc...which is why I am asking. I have extensive fabrication experience and equipment. Laser cutting, press brake, Seigmund weld fixturing table, etc...the fabrication is not an issue. Just looking for input to help me decide whether I want to go down this road or just weld up the factory one, powder coat it and put it back in the car.
Thanks in advance. :)
They are not ridiculously heavy.
They are far more rigid than any tubular K member. Your front end will be stiffer with a factory unit.
One issue I would see is ensuring the suspension/steering parts are correctly located for proper alignment. Another is the strength of the structure itself to withstand the weight and loads applied to it.
Sure, it's heavy and sometimes poorly welded, but they are strong. I'm sure you could take a lot of weight off by doing this, but how strong will it be. Application, drag cars is what I see. Others would be for special engine applications like Gen III Hemi's or other setups. I like torsion bar suspensions, but have never thought of why one would try to redesign it. Most of the aftermarket suspensions i have seen just don't look strong. This is coming from a person that had a aftermarket Mustang II suspension almost kill him in a 32 Ford street rod. Chrysler had strong designs. I say clean it up, eliminate funky welds, paint and use it.
While thinking of your endeavor, consider weight of a complete engine along with gearbox, lift forces, lateral forces, as well as the geometric design for steering and suspension, engine mount orientation for proper driveline alignment, along with tensile strength of metal utilized in the construction. Oh... and don't forget that oil pan that might get in the way. On the other hand, the factory engineered proven part...
If you're attaching an engine that weighs 600 lbs and the most you can realistically save is 22 lbs (that's if you could halve the weight of the factory unit) with an unproven design of unknown strength and durability, then as said above - why bother?
But - you said you have extensive skills and the equipment, so if you actually enjoy doing this sort of thing then why not? Have a crack and show us what you come up with. If it works, then others may adopt your design. If it doesn't, then so be it, at least you tried. Plenty of times I've tried to improve something, wasted hours doing it and then chucked it away when it didn't work, but I had fun trying. Innovation, I love it.
Same here. I love to paint outside the lines and do some things different than what is OEM. I see nothing wrong with trying new things.
If one could build a tubular K member with some manner of reinforcement that actually ties the frame rails together....while resisting the tendency for the front structure from parallelogramming, it would be interesting.
Think of how a wood framed wall is built. A series of studs are attached at the top and bottom. It is excellent in compression but is not good at resisting torsional resistance until plywood sheathing is applied and nailed....At that point, the wall is super rigid.
The factory K member resists torsional shifts because it is rigid. The sheet metal used in it acts like the plywood on a wall frame.
You could duplicate that in some manner with a tubular K member but you're blazing your own trail on this since nobody else that I have seen has done it.
