Anybody stack head gaskets for quench
3sloppydogs
2:50 AM
carroll county MD.
I need about .040 for a better quench. I'm to close now. I have an extra set of fel-pro that will raise the quench to a tolerable clearance. I am cheap too, so having said that I could stack the gaskets and that would work and save me some cash. I don't want to spend big money on a pair of gaskets if I don't have to
Anybody do this?
A standard Felpro .039" isn't close enough?
Cosmetic makes them. Expensive, but reusable if you have to pull heads. Great for SC applications.
Yeah Cometic might be your only choice. Talked to one of their reps a while back he says ok to reuse for mockup but not after being run. IDK but for their prices I would clean them up and hit with copper coat.
I have the fel-pros. If I stack them i can get the clearance I need. The problem is the piston has a rise above the valve relief, they are KB something and the heads are edlebrock with no relief outside the chamber so the quench is about 010. If I use the single fel-pros it doesn't raise the head enough for proper quench,hence the question about stacking
Sounds like you are using a KB reverse dome with a closed chamber Eddy head. I used them with 906s and the FelPro and still had to clearance the head a wee bit.
Early hi perf 409 chevies came from the factory with stacked head gaskets. Racers pulled one set out.
Then again, that's how the apocryphal story goes......
(And the oh-nine didn't have a combustion chamber)
