steve340
If you install a vented gas cap you will most likely get a fuel leak from the cap. No good.
I tried reversing the tubes still did it. Made sure no tubes were blocked - no good either.
The tank is vented to atmosphere (it has to be for the fuel pump to work) so the fuel smell while parked could be just fumes coming off the fuel and gathering under the car as fuel vapour is heavier than air. There is no evap canister on a 1968 like a modern car would have to capture the fumes. My car did that and it would puke out and stink after being parked a while.
Yours sounds like the same thing I had. I thought it is OK all old cars are a bit smelly.
My gut felling was the smell was too strong and I was worried about the fuel smell and it turned out I was right - there was a problem.
Is the fuel smell in the garage stronger than you are comfortable with?
Do you get a fuel leak from the passengers side rear chassis rail where the other tube goes to?
Fuel drips out or may be trapped in the chassis rail down by the front of the leaf spring.
Do you ever occasionally notice a smell of fuel for a minute or two and then it disappears when you are driving along the road?
