Dakar Timm
- 7:08 PM
- Nov 14, 2020
- Lake Mills Wisconsin
I finally finished the replacement floor pans . Only problem was when I fired it up to take the car off the ramps coolant ran “ quite freely “ from where it appears to be behind the timing chain ?
As far as I can see , it is not coming from the water pump or the intake manifold . I wiped both completely dry before firing up the car again . Is it possible that a gasket in the timing cover blew ? The motor is a 318 Polyhead if it makes any differance
