As everyone ever try to made their own tubular K-member ?
Pinto parts. Mustang parts. Tubing cut and welded using a tape measure for "precision".
Thousands of dollars spent to gain some header clearance versus spending less than half to have similar handling and less durability. I'm still not convinced.
Nobody has proven that any aftermarket front suspension gives any competitive advantage on the road course over a well prepped stock based torsion bar suspension.
Thevendors in the aftermarket are plenty happy to tell you different and to take the money though.
The advantages of the aftermarket stuff?
Header clearance? Buy decent headers instead of Hedman or Hooker.
Adjustability? Tell me how ride height isn't adjustable on a torsion bar suspension.
Steering feel? I guess nobody told you about the Firm Feel or Borgeson steering setups ?
Hey....If the goal is to look cool and modern with the new and flashy stuff, I can appreciate that. Just understand that you are spending a lot of money to go no faster, handle no better and to last no longer than a properly improved factory setup.
as circle track racer who maps out and builds front suspension i can tell you the stock front end geometry and components are junk. i have taken a stock 70 charger on a 3/8 banked oval and it was slow as ****. it did haul *** down the straight but man did it push bad, i mean one of the worst handling cars ive ever tried to drive hard. if you do the roll center from the control arm angles its junk. if i used that geometry on my circle track stuff it would push horribly. even on my car ill be replacing the k frame even though i modified the hell out of it just to get better geometry soon. the lower control arm balljoints need to go down about 3". the pinto spindles puts the balljoint back on the lower instead of the spindle giving it that drop that it needs. also the bumpsteer is way off on the mopars with the drag link having a drop to it instead of being centered with the pivot point of the lower control arm and outer ball joint center. the bushing setup on the original torsion style is garbage. everything is so sloppy on the factory lowers. aftermarket bushing control arms have a sleeve thru the urethane bushing thats greasable and freely spins in the bushing, the stock setup...nope, works off just the flex of the spongy bushing. so as your cornering under heavy load the caster and camber is being changed from big spongy sloppy bushings. if you wanted a lowered car the balljoint angle is way off on stock lowers aswell.
so by going with a modern front end geometry k frame you will save alot of weight, go faster, handle better and last much longer than the factory k frame suspnsion. all around waaaaaaaaaaaaaaaay better
My first lower control arm on top....RMS lower below.
Hi there ,I have a 72 Roadrunner 505 RB ,ford Automatic Overdrive trans .I am building a front end measured of an rms ,but styled more on the control freak set up as the box section RMS one looks terrible,looks like they have just slapped it together expecially the steering rack mounts.I also copied the street lynx rear end,they have some nice pictures and tell you the measurements of the linkages. I emailed Andy Helgeson at viking shocks he told me which spring rates and shock lengths RMS uses for the front and rear end.if any one wants to know measurements and part numbers I can supply them ,but they are in metric .haven't quite finished the front end yet,the sway bar I make out of 1 1/8 4140 just heat it up around formers and leave to aircool
WP_20150503_15_41_01_Pro.jpg WP_20150503_15_41_09_Pro.jpg DSC_0009.JPG DSC_0010.JPG DSC_0011.JPG
Hi,
what a cool set up you've got ! The mesuerements would be a great help ! :) RMS give them to you ?
Thank you !
Good read! I kinda agree with both guys earlier , on that it is a TON of work and money for only header clearance it seems and unless you are pushing the pedal into the carpet in the turns it would make more sense to just throw a set of TTI or Schumacher headers on it . On the other hand there is always a bit to be desired for the stock suspension and handling could always be improve upon . Like most other things in this hobby , budget and planning to figure out the best bang for your buck , don't forget to figure in time !
