At idle front wheels turn to the right.
64SF
8:36 AM
Ocala,Florida
At idle the front wheels slowly turn to right without touching the steering wheel. Any thoughts?
Need to adjust the port valve on top of the gear box. Loosen the 2 bolts and move back of forth til you get balanced between right and left. That's my guess.
Tip...Don't loosen the bolts too far. Just enough to move the valve.
...and you BARELY need to move it! Moving it forward will make it turn left, moving it aft will make it turn right. You want to slip yours forward, but like I said, just a little bit...like a 1/16 or 1/32 of an inch. If you can scribe or 'sharpie a mark before you start so you have a reference point.
