At what point did NEW lifters become junk out of the box and were.......
Lubrication may not be the issue in the majority of cases but it is worth attention.
I put a '528 solid in my 440/493 in 2014. It had the Howards EDM lifters. For years I ran Royal Purple, then Valvoline VR1 with a bottle of Comp Cams break in supplement. Early 2022, I switched to a synthetic that supposedly had "added zinc". I didn't drive it all that much until the 950 mile trip to Southern CA and back in May. Just over a week after that trip, the cam shed several lobes with 10 total going bad after closer inspection.
The parts did not change. My driving habits didn't either. The only change was to the bullshit oil...
But...it has EXTRA ZDDP !
Unfortunately, the high detergent found in oil with this API label...
Meant that whatever ZDDP was in the oil was not going to stick to anything since the oil was high detergent.
Lesson learned there. The right oil absolutely matters.
Lake Speed, the Motor Oil Geek, has interesting videos on oil...& zinc. It is about 20 min, maybe somebody can link it. Oil with 1200ppm Zinc was used with FT cam, no issues.
Then a Zinc 'supplement' with 3600 ppm Zinc was added to the oil. Cam/lifters failed soon afterwards.
Moral of the story: get the correct oil & do not add supplements which can & will destroy the sensitive chemical oil package.
I have to inspect my 318. But, the switch to solid lifters involves? I will assume the solid lifters replace the hydraulic units. Now there must be some form of adjustment. I switched to adjustable pushrods earlier. However I think that is not the answer. So there must be some other changes to be made to the rocker, and the new rocker has the adjustment.
And, is there any more noise from this arrangement?
A steady tapping from all the rockers, would be more acceptable than the single ticking sound that I now have.
You need adjustable rocker arms and the proper push rods, so it’s not cheap.
Many a little noisy but not more than the Rhoads hydraulic lifters I was using before. Just get louder mufflers.
No you don't need adj rockers arms. You can use adj push rods. Isky cams make a large range. Price difference between the prods & adj rockers might be close, but you will still need p'rods. Keep the lash to 0.006-8" hot & you will have very little noise, plus these benefits:
- lifters cannot bleed down
- lifters cannot pump up
Thank you Geoff. I have adjustable pushrods. They are a bit thicker than the stock units. 5/16 and 1/4 from memory.
My plan was to adjust them with the inlet manifold removed. That would allow a bit more room. I will remove tne manifold to remove the hydraulic lifters, and inspect the cam.
Not to hijack, but have apparent lifter bleed down issue, cold startup clatter. 440-6, lunati 60303/lifters, SRP 10.5:1 forged pistons, steath heads, stock 1.5 rockers, Manton 3/8 pushrods. Tried slightly longer pushrods, + .030. Clatter went away for awhile but returned. Assuming 1 or more bleed down issues, what would you guys recommend? Replace only bad lifters, new full lifter set from lunati, new cam/lifter package or?
If you go bumpstick/lifter package, check into Howards offerings. Specifically their Max Certified line. I'm going to use one of those for my 440
Howards_2021.qxp_2005Howardscurrent vers .QXD4 copy 6/24/24 9:49 AM Page 6
The First and Only No Worry
Hydraulic Flat Tappet Cam & Lifter Sets
Confidence! That’s what you get when you install a New Max Certified
Cam and Lifter Set. A superior product with quality control goes far
beyond, including batch testing and verification on an Adcole 911NT.
The Adcole is the premier measurement equipment for camshafts in the
world. So you know you’re getting the finest camshaft for your applica-
tion available. Each set includes a performance hydraulic camshaft, a
set of matching hydraulic flat tappet lifters and a bottle of Max ZPM oil
additive for break-in (Max ZPM must be added to every oil change). So
what happens if you still have a cam damaging event?...You’re
Covered! We will replace your Max Certified Cam & Lifter Set at no
charge for up to five years from date of original purchase. Just com-
pletely fill out the supplied warranty card and return along with your
camshaft, lifters and the original receipt. No worries that you may have
overlooked something that damaged your new Max Certified camshaft.
Didn’t notice that retainer to seal clearance wasn’t enough?...Covered!
Valve spring coil bind...Covered! Have a problem with your oiling sys-
tem that damages the cam?...Covered! While installing the cam, you
drop it and it breaks in two?...Covered! So what are you waiting for?
Isn’t it time to make a real performance change to your engine? With
Max Certified Cam & Lifter Sets you’re covered! For extra insurance
most kits available with Direct Lube lifters.
* Max Certified warranty applies to Max Certified Cam & Lifter Sets only. Max Certified 5 year
warranty starts from the original date of purchase. Any and all replacements are covered for
the remainder of the original warranty as long as any or all repairs or adjustments to end user’s
equipment, determined by Howards Cams, is completed. Max Certified warranty covers the
camshaft and lifter set only. Warranty does not cover removal/installation cost, damage to relat-
ed components, cost incurred due to down time, towing or shipping.
