Not to hijack, but have apparent lifter bleed down issue, cold startup clatter. 440-6, lunati 60303/lifters, SRP 10.5:1 forged pistons, steath heads, stock 1.5 rockers, Manton 3/8 pushrods. Tried slightly longer pushrods, + .030. Clatter went away for awhile but returned. Assuming 1 or more bleed down issues, what would you guys recommend? Replace only bad lifters, new full lifter set from lunati, new cam/lifter package or?
If you go bumpstick/lifter package, check into Howards offerings. Specifically their Max Certified line. I'm going to use one of those for my 440
Howards_2021.qxp_2005Howardscurrent vers .QXD4 copy 6/24/24 9:49 AM Page 6
The First and Only No Worry
Hydraulic Flat Tappet Cam & Lifter Sets
Confidence! That’s what you get when you install a New Max Certified
Cam and Lifter Set. A superior product with quality control goes far
beyond, including batch testing and verification on an Adcole 911NT.
The Adcole is the premier measurement equipment for camshafts in the
world. So you know you’re getting the finest camshaft for your applica-
tion available. Each set includes a performance hydraulic camshaft, a
set of matching hydraulic flat tappet lifters and a bottle of Max ZPM oil
additive for break-in (Max ZPM must be added to every oil change). So
what happens if you still have a cam damaging event?...You’re
Covered! We will replace your Max Certified Cam & Lifter Set at no
charge for up to five years from date of original purchase. Just com-
pletely fill out the supplied warranty card and return along with your
camshaft, lifters and the original receipt. No worries that you may have
overlooked something that damaged your new Max Certified camshaft.
Didn’t notice that retainer to seal clearance wasn’t enough?...Covered!
Valve spring coil bind...Covered! Have a problem with your oiling sys-
tem that damages the cam?...Covered! While installing the cam, you
drop it and it breaks in two?...Covered! So what are you waiting for?
Isn’t it time to make a real performance change to your engine? With
Max Certified Cam & Lifter Sets you’re covered! For extra insurance
most kits available with Direct Lube lifters.
* Max Certified warranty applies to Max Certified Cam & Lifter Sets only. Max Certified 5 year
warranty starts from the original date of purchase. Any and all replacements are covered for
the remainder of the original warranty as long as any or all repairs or adjustments to end user’s
equipment, determined by Howards Cams, is completed. Max Certified warranty covers the
camshaft and lifter set only. Warranty does not cover removal/installation cost, damage to relat-
ed components, cost incurred due to down time, towing or shipping.
