Available Mechanical Fuel Pumps with 3/8 Inlet
Speedbird
Bird of Pray
7:53 AM
Status Quo
Is there any reason this pump could not be used on a B 383 engine.
I would "assume" all stock type RB and B pumps are physically the same as far as mounting and lever.
So stupid question time.
I've got one of these.
https://www.summitracing.com/parts/CRT-M4845
Either it has too much meat by the aft bolt or I've got too much engine block there to clear it.
Hoping for the latter and I'll make it work.
Thanks.
I was bass ackwards in what I said.
I ain't grinding the block if I can help it.
The aluminum is what I meat.
Er I mean meant.
Having a bad day with my M and Ms.
I put a Carter M4845 on a 1970 440 last year. It didn't need any grinding. I bought a fitting for the output side at napa so I could use a 1969 and older fuel line on it.
