AVS 4640SA Carter vacuum inlet
RT SE 440
5:02 PM
australia
Hello guys just put a new carby gasket on & now the vacuum advance is not working as i have no vacuum at the carby end i think the carby gasket hasn't got the cut outs for the timed vac ports on the base plate can someone post a picture or draw a mud map of a base plate were the ports are thanks
Pretty much self explanatory.
timed port should be above the gasket and throttle blades. shouldn't show much if any vacuum at idle.
See circled port. That's where the factory puts vac advance on ported vacuum. There will be no vacuum there when in neutral no matter how hard you rev it.
The base gasket can't do anything to block the ported vacuum it is created internal inside the carb. The only cut outs are the 4 large holes for the throttle plates.
are you saying if we put it in drive, will we then see vacuum? :p
lewtot184 and R413 nail it, the flange (base) gasket cannot really interfere with either vacuum ports.
the front vacuum fitting, going to the distributor vacuum advance, is connected, more or less, to a port above the throttle plates inside the throat passage with the venturi. when the throttle is at idle, and the plates nearly fully closed, the port is "seeing" mostly non-vacuum air above the throttle plates. but as the plates are opened, the port is exposed to more of the vacuum from the manifold, and that is fed to the timed vacuum advance port on the front.
the side vacuum fitting, going to the choke pull-off, sees lots of vacuum at idle, and is fed along that channel shown in pnora's photo (upper left). note this channel is below the throttle plates, and is exposed to manifold vacuum as the engine is running and is sucking air/fuel, regardless the position of the throttle plates.
you should see vacuum on the front fitting, with the engine running (even in neutral, ha ha) as you open the throttle slightly. There may not be a ton of vacuum there, so a vacuum gauge can be helpful to test it.
As you rev the engine up, the mechanical advance in the distributor should apply timing advance, too. If you're not seeing ANY advance, could it be possible your testing method and/or tools are to blame?
Thanks guys didn't realize that the vacuum cut in as you rev the engine but do now.What i also notice with the vacuum connected to the vacuum advance the engine hesitates a little from a stand still position but when it's blocked off it doesn't hesitate at all.Is this normal ?
The diaphragm in the VA unit might be leaking. Remove the dist cap & look at the VA actuator. Suck on the VA hose &n the actuator should move. No movement indicates faulty VA unit.
Another possibility is not enough initial timing, especially if the engine has a hot-ter cam.
