CHARGERSTEVEN
It is the rite carb for your car as i have the same one n a R/TSE 69 CHARGER but ive never experenced any problems like your describing,i would think as my best guess as being dirt inside or just bad gas
Dirty gas, maybe a few pieces of crap in carb. Miles since '18? Might be time for overhaul?
The major carb difference between cars with auto trans and std trans are primary booster venturii as ALL idle and off idle fuel originates in the boosters. In addition, the metering rods are different size in the down position. The metering rods and jets control the fuel delivery when the boosters are feeding fuel; but idle fuel originates in the boosters thru fixed fuel and air restrictions and of course the mixture screws. Carbs used with A/C equipped cars have a thermostatic controlled air bleed to elevate an over rich mixture due to hot under hood temps.
I've seen both 69 & 68 models with the single idle mixture screw. This is about the same time as the "off idle air bleed" appeared to elevate a leaner off idle transition due to increasing emission requirements, in addition to altered distributor advance characteristics. Sometimes, a dashpot (manual trans) or a anti-diesel solenoid was also included...on '69 - '70 + models. Not sure that answered your questions.
BOB RENTON
Took it for a drive today and put gas and treatment in it. It may have helped a little but the tach is showing 500rpm or less which I think is too low - had a lot of stalling in reverse putting it back in the garage. Had to two foot it. Otherwise, it ran great.
