eric383
After the tires I would check the trans mount and then have the driveshaft balanced. Good luck.
That is what I was thinking.Put the rear on jackstands,,,,start,,put into gear and look at the DS.It's straight or it's not........Bent or out of balance drive shaft?
Well you have my number if you need to look further, if the problem persists!Well I managed to get the tires looked at by a reputable shop here in town, and got see interesting news. Turns out, the tires are too big for the rims. Apparently the tires are for rims that are 6-7.5" wide, and mine are only 5-5.5" wide. The shop didn't want to Roadforce them (I didn't either actually) because it wouldn't prove anything.
Monday I will have a new set of 215/70r14 tires put on.
They also said all 4 tires were badly chopped, so I may have to replace the "new" shocks on the car to make sure they aren't jumping around.
I would check the torque on the axle nuts if it has the original rear with tapered axles htey need to be at least 100 foot pounds.I certainly will! Once I get the tires and new pitman arm installed I'll keep everyone updated!
That will work.Thunderlugs we may stop out today. We are at a show until 4. I'll give you a call before we leave.
Nice work!I'm back with an update! With the help of my dad we got the passenger front corner torn apart. It came apart surprisingly well. As expected, all bushings were trashed beyond hope.
After $200 in bushings and steering components, the rebuild started. Driving the old bushings out was...interesting. Between an air hammer and a U Joint press, we managed to get them out.
He got the lower one back in and the whole bottom passenger side put back together pretty quick. Upper bushings will come tomorrow, then it's on to the driver's side!
In the meantime, I went ahead and managed to mangle my right ankle (and fix it too?), along with touch-up some areas on the body and repaint the rockers. As of tonight I finished hanging some decent exhaust to get the PO's booger welded exhaust off.
Fun stuff!!
View attachment 495843 View attachment 495844
