I just went thru the whole ballast thing here earlier this year. I've got a whole thread on here on this very subject. It's got wiring diagrams and all sorts of experimentation on this; I wore the subject out, pretty much.
What I discovered was that the previous owner had, for some reason, used the wiring for a mid-70's Mopar electronic ignition setup when he "converted" my GTX to electronic ignition, including the double ballast.
A learning process for me, since I am used to just using the Mopar kit and replacing the regulator with the electronic one.
The Mopar electronic ignition kit (orange box and all) INLCUDES a new ballast that Ma Mopar wants you to use. I always figured they knew more than me, so I used it when I'd do the conversions.
I have the MP electronic distributor and orange box now, along with an MSD Blaster coil.
Long story short, I discovered the previous owners' rigging had the ballast only sending like 5V to my MSD coil - which led to high RPM misfiring!
Lots of experimentation with different ballasts and my trusty ohm/ voltmeter led me to fetching the MSD ballast that is only 0.5ohm, which gives me a perfect 12V to the coil during running.
That cured about everything, right there.
Yes, I know I could probably run totally without a ballast, but like I said before - Ma included one in their kits and they know a crapload more than I do about these things, so I run one.
