vance.dykes
make sure the alt is grounded to the engine and that the engine is ground to the body a bad ground will over chargeThanks for all the responses.
It’s a single wire alt with an internal regulator. Just ground the case and a single wire to either the positive battery post or the battery post in the starter relay.
I will check my handheld cheap volt meter. Maybe it’s bad. I will also pull the alt and have it tested.
Thanks Jeanette
