67MPRFAN
Then I am thinking something alignment wise has changed.
Are you using your old crank pulley or the one off the new motor?
Yes same pulleys off the old motor never had a issue with belt
Yes last belt was fine until I took the car out for first test drive with new motor, went to O'Reilly pick up another for 6 bucks try it and broke it then try 1 from advance auto for 16 dollars it twisted, started looking things over found the miss alignment between crank and wp pulley added shims got a napa belt for 20 was able to drive around normal then I said okay let's feel the power of the 470 bang flew off again,Sure doesn’t look like your belt it tight enough in that video.
Did you say the last belt was fine but broke, never jumped off? I had a real bad time with repop belts from Quanta. They jumped, turned inside out. Maybe try another belt. I have good luck with Continental.
You could always lower your RPM too![]()
The best tip I received for checking alignment it to use a wooden dowel laid in the pully grooves
If it comes off at high rpm's, get a different sized crank pulley and I noticed you said the belt only had problems with the "new motor". So this was an old belt ?
Get a high quality belt like one from Gates. You might want to change pulley ratios if you are constantly driving with the engine wound up.
Here is a picture of what I am saying to do. A picture truly is worth 1000 words. And, giving the belts a good push with your finger, you should have about 1/2" of deflection on the longest run.
We'll have to agree to disagree.Nice, but too easy to deflect.... Paul_G's got the best way, IMO..... You can lay that in the grooves too
Thats great, now you can see how much it is off, and that is a lot. Is the water pump pulley to crank pulley in good alignment? If so the alternator needs to move back toward the engine.
