Bond jumper
I used two, going from the bolt on the back of the passenger side head to the bolt on the ECU and to the bolt on the voltage regulator bracket.
BTW bonding is a supper common term in construction, when you connect the electrical panel or the steel frame of a building to a cold water line or ground rods your bonding to earth ground.
Don't know if you're looking for OE or just one to replace, they make many different sizes and styles..., and are usually copper/ aluminum or copper clad....Oriellys or NAPA should be able to hook you up...View attachment 314982
I found those. Again, I remember seeing part of it on the firewall but one end was broke. Now looking to see where it went to and for what?
Same term in aviation to protect electronics etc
