Bought a new M&H under dash wiring harness for my 67 Charger- Installation tips?
Dean Prevolos
3:07 PM
Naples, Florida
Before i start my installation of the under dash wire harness I thought I would ask the Forum members for any tips. Questions I have are:
1. Can I install the harness without removing the windshield? I know the windshield has to be removed to remove the dash but is that necessary to install the wiring harness?
2. If I don't remove the dash from the car, I assume I will remove the gauge cluster, drop the steering column, remove the radio, glove box to gain access but will I be able to reach the bulkhead from the inside without removing the steering column?
3. I have labeled all the new wires from the service manual wriring diagram, are there any recommendations as to where to start the installtion? Do I connect the bulkhead first and then the wires to each component?
4. Besides testing everthing before I put everything back together, what other advise can be offered?
Thank you in advance.
I replaced the dash harness in my 67 Satellite without removing the dash, windshield or radio. I dropped the column to remove the cluster, but didn't remove it completely. I worked through the cluster and glove box openings with the seats and console in the car. I might remove those last 2 items if I had to do it again only because it's getting hard to contort my body like I used to. The bulkhead connector is difficult to reach and push the locking tabs into position so I tied strings to the tabs - one top and one bottom - and pulled it through from the engine side. I also removed the fuse box and added connectors for new auxiliary items that had been added like gauges, etc. to remove all the old splices while it was on the workbench prior to install. Hope this helps and good luck!
EDIT: It's been a while but I believe I started with the bulkhead connector and worked from there.
I plan to do this over this winter.
Remove driver's seat
remove steering column
remove instrument cluster
I think I can do it in a day , two tops
I have no intentions to remove glass or dash frame itself . Console is a maybe, just depends on how contorted i need to get my body.
work from the firewall bulkhead connection back
The kick panel on the driver said anyway needs to come out as there are a couple plug connections behind it. I replaced my bulkhead box in my 67 last year and did not remove the column. I lowered it. I did a whole dash harness in my 66 a few years ago but I had the interior pretty gutted at the time. The bulkhead is a bit of a pain to get to. I believe I hooked string twine through the clips and into the engine bay, put some dielectric grease on the clips and pulled it through to latch into place by the twine. I would remove the drivers seat but you can probably do OK leaving the console and pass seat in.
A couple suggestions, when you get the old harness out, go through each plug and compare the new one with the old one. Twice, installing new harnesses I’ve found 2 wire positions accidentally switched in a plug. It can ruin your day the first time. The second time it was a simple correction before installing.
Check grounds and wire crimps on all grounds, and also on other terminals. I had a headlight circuit ground issue up front on my 66 that was giving me fits until I found that the ground ring had been crimped in both crimps on the insulation. The furthest crimp is supposed to be on the bare conductor but they accidentally crimped it on the insulation.
Good luck.
I added some and repaired some of my wire harness by doing exactly like you thought you could. And yes, remove the front bucket seats.
Yes to# 1 and 2
I'd be happy to test/reflow solder/replace the IVR on your cluster!
I just did this last summer, once you get started it'll be smooth sailing. The M&H harness are so nice and pretty self explanatory. I didn't remove windshield but did remove radio, I had steering column down and front bench seat removed.
Thanks to all of your suggestions. I did remove my drivers seat so I could access under the dash better. I am 72 and my back is not what it used to be. I like the idea of pulling the bulkhead up with strings from the engine bay side makes sense. And the dielectric grease is also a good idea. I was concerned about getting that fastened in place on the bulkhead. I will lay out the original harness and check it against the new harness. I have already found one connection that made no sense until I called the M&H TECH in California and he told me to what to do for my car , which is a 4 speed manual verse the automatic. I feel much better with all your recommendations and will start this weekend.
Thank you ALL!
I already had that completed by Todd Castner(Todd's restorations). Everything actually worked except for the light in the fuel gauge, which he fixed. Thank you for the offer
Now that the Thanksgiving Holiday has passed I went to my garage yesterday to remove my under dash harness. I dropped the steering wheel and removed the intrument bezel, radio and disconnected the heater control unit. After unplugging all of the connections to my gauges, I started at the driver footwell to remove the wires, then proceeded to the other footwell, headlights, etc. I then brooght the harness wires toward me through the dash bezel opening. I then disconnected the fire wall connections in the engine bay to the bulkhead and unclipped the bulkhead to drop into the car. I pulled out the harness through the dash opening and laid it next to my new harness. I examined each connection and found one extra blue/white wire branching off of the bulkhead connector( see attached photo). Not sure what that is for but it appears to be an extra plug provided by M&H. Maybe for an automatic car or other accessory? If anyone knows what it connects to let me know.
After reviewing the new harness, I set it into the cavity and started laying it out, first from the opening in the dash and then laying on my back under the dash. I took both front seats out. My car is a 4 speed with a buddy seat, which I left in place. My back was a little sore from the many times of getting up and down all day but nothing a few Tylenol can repair.
I then went to the task of installing the bulkhead connector. I tried the strings but the 4 tabs on the bulkhead were just too hard to pull through the firewall. So I removed the strings, put some grease on the 4 tabs and just pushed as hard as I could from reaching through the dash opening. Well the top two tabs snapped in but not the bottom two. After too many trys, I took a long cardboard tube, that had plastic caps on either end, and I laid it through the dash opening to rest on the bottom of the bulkhead connector. I gave it a good wack with my flathead hammer and it snapped in.
I am going back this morning to finish. I'll report on how it went and if everthing works.
I want to follow up on the underdash wiring harness. I ended up calling M&H to ask about the purple and white wies that were a separate plug on the new harness. It turns out that because my car is a manual shift trans, those two wires are for my backup lights, so I had to remove the plug and just plug each wire into the appropriate slot on the bulkhead connector. So I removed the bulkhead connector, installed the two wires and then reconnected the bulkhead connector. The second time was the charm and I was able to secure the bulkhead connector by pulling the bottom two tabs through the firewall with a set of needle nose 90 degree pliers I have. Just slid the plier prong through the bottom of the tab and pulled into place. Everthing works on the car dash, rear tailights, front lights, etc. The only item that the harness did not have was the wires for the heater controls and heater box. The harness does have the power wire from the fuse box for the heater contril but the other wires I will have to remove from my old harness and splice into the new harness. I chose not to do that at this time. Darrin at M&H harness was helpful with my phone calls I made to ask questions as well as responding by email. So that's my story , glad I did it mysef. Thanks for all the Forum members advise on the steps to take. Happy Holidays!
Just used needle nose pliers with 90 degree bend to pull those bottom bulkhead tabs through when I did mine, way easier than the string method.
Yes it was. I tried the string method the first time and it went nowhere. Glad to hear there are two of us up at this hour on the forum!
Usually the replacement dash harnesses require the re-use of the originally accessory harnesses - radio, heater, air conditioning, console lights, clock, tach, etc.
Live to Learn; Good to know now if I ever do another Charger harness. Fortunately the harness did have all but one set of wires for my heater control and heater box.
Thanks for your help on this project.
After reading your response yesterday I looked at my old harness and removed the original harness for the heater control/heater box fan and installed on my new harness. Thanks
