Brake Distribution Block question
OldRunner
5:38 AM
Ontario
I am doing a Power Front Disc Brake conversion on my 68 Coronet. ( which had manual brakes ) . I was sent an adjustable proportioning valve to use, for the rear . My question is can I use the distribution block that is on the car for manual brakes. Or do I need to buy one for Power Brakes ?
Thanks
You can use that old distribution block you have. Just make sure you install that adjustable proportioning valve in the line to the rear brakes and you're good to go.
prop is correct,factory block will do fine.i normally install my adjustable valves just after the diverter block in the single rear line.makes it clean and simple.
