Broken 727 Transmission Starter Pilot
LSS&B
10:22 PM
Aylett, VA
@Dave6T4
Starter mounting bolt holes are OK. Plan to use high-torque ministarter.
Starter Pilot broken on my 1967 727 transmission case.: Is case useable?
Bell housing before clean up. Starter mounting bolts look OK.
So its not really needed - there are starters sold that do not use this pilot hole. I like to use it. It is repairable, but is it worth it? I have the capability to fix that in my shop. But if it were mine, I would replace it. But I also have several spare cases.
Like said above the outer half is intact and that will locate it. The starter has a wide flange and two 7/16" bolts holding it down.
I would run it!
Too many rear wheel drive GM products in your space?
LoL no, those are OLD bad memories. I have only one GM product these days.... a '16 dump truck that I bought brand new. Not ironic i guess, the starter failed when the truck was about 8 months old. /rolls eyes
Post#2 Requested a test fit. Looks good to me. I don't think the gap between rear of starter and bell housing will make a difference.
You will be FINE. As I said earlier, the force when cranking is trying to push the boss outwards, & the boss is ok in that area.
Awesome, Geoff! Thanks. Already have 2 transmissions a part in my garage. Don't want a 3rd. Ben might get cconfused.
:realcrazy:
