Yeah those low crossrams or any box manifolds easy for parts to jump
from side to side...
I had a 440 with a STR-14 4bbl dominator top
that did that too, like 6,5000 rpm
it broke off an intake valve & bent another
from the same broken valve I suspected...
Off of or in an earlier version of Stealth heads...
Foreign **** Chinese-ism 'alleged S-S' valve
(**** metal had all kinds of porosity in it),
that they/it came with & they were almost brand new too...
It wiped the bearing/s, scored the crank, (polish took care of that)
1 cylinder lil' scratches where the valve head dropped
& 2 pistons beat to hell & bought some good all new Manley SS Valves
for both heads, they were ported heads too...
More expense, I was lucky my head porter Mark Lowe (RIP) helped me out...
I had to try to match the other head, so we just went
a bit further with the port job, so both would match/flows etc.
I wasn't going to take any more chances...
I luckily caught it soon enough, it didn't ruin the cylinders,
just a hone cleaned it up...
Cam & lifters (Lunati or maybe Crane ?)
pushrods (Smith Bros)
rockers (Harlan Sharps) all seemed fine,
Melling HV oil pump had some stuff go thru it, so I put a new one on it
flushed it all out really good...
A call to Uncle Joe's, his Venolia pistons, he sent me 8 all new pistons,
with a lil' more compression zero deck, lil' bigger valve reliefs like 8cc's
'while I was at it' (IT had 0.120" clearance valve to piston reliefs prior too)
& new Childs & Alberts new rings/bearings & rod bolts,
Magni-fluxed & x-rayed everything to make sure, no damage or cracks
& 1 new *whole head it was pretty bad, I didn't want to repair it
& take that chance...
(they *440source made it good, the 1 head that is, he sent a head gasket too)
A month of BS, PITA was the worst part...
Tri-Valley Machine, Pacheco Ca. Manuel got right on it, did a great job...
Another $1500 in machining, parts & gaskets I had to pay for...
Could have been way worse...
Live & learn....
My race motors with 8 stack fuel injection never had them issues
it can't travel from cylinder to cylinder, unless it goes up & out
& then gets sucked (1 in a million) down another injector stack
out of thin air...
On my tunnel rams either, maybe just got lucky...
