- 11:14 PM
- Apr 13, 2012
- Granite Bay CA
I have had it with poor street manners. This big cam and high stall converter combo just ain't my thing.
I'm not a drag racer. I do enjoy some straight line fun but cornering is more my thing. Road race, top end, slalom, stuff like that is what I enjoy.
Last year I pulled the '509 cam from my 440/493 in the Charger and slipped in a lumpy Lunati solid lifter cam because I was told that it would eliminate my detonation problem. It did not. What it DID do was actually make it worse since the IVC turned out to be earlier than the 509 cam. Lesson learned? INFORM myself better before making any changes. The 316/326 Lunati has made the car faster than ever at WOT but somewhat lacking in the idle to 3000 range where I drive most of the time. To reduce the detonation, I ended up going with thicker head gaskets which have worked exactly as intended. ZERO knock since january when I made the switch.
After months of reading threads on websites, talking with knowledgeable people and fellow gearheads, I've decided to switch to a smaller cam abd a tighter torque converter. I know that this may make me look like I'm wimping out, but I don't see it that way.
Today I ordered the Mopar Performance 284/528 solid, a set of Howards EDM lifters and a 3 bolt Howards timing set. I also called Lenny at Ultimate Converter and he is building a 11" TC for the car. The 528 cam has a 112 LSA which will deliver better idle vacuum, a broader power band and reduce the risk of detonation. Similar builds using this cam have made 600 lb/ft of torque and 540 or more HP. They all seem to peak under 6000 rpms which is ideal for me.
Stick around. As soon as I get all the parts in, I'll post some results.
