Can anyone identify these after market rims?
Robliepse
2:41 PM
Buford ga
I picked up this Satellite to use as a donor car and it has some cool rims that I think I have seen before but I cannot find any information on them. photo (5).jpg
Those look just like Ultra wheels. I had a Monte Carlo SS that had Ultras and the plastic center caps eventually turned loose where the tabs held them on.
Do yours have 5 slight depressions around the center hole?
I'll have to check the 5 depressions. The car's not bad for a donor. Pretty good metal but it's a front drum brake car without sway bars. All the wiring is gone and the only thing of any value in the interior is the high back bench seat and the steering column. It's got a decent 400 and a nice 727 that the guy I bought it from says runs. I also got a lot of brand new still in the box parts that I don't really need like a Weiland intake, champion 3 core radiator with dual fans, fuel sending unit, aftermarket floor shiftier, transmission lines, alternator, battery, aftermarket EZ-Wire full car wiring harness, starter........... The car does have the power steering pump and gear, AC box under the dash, Headman Headers, and brand new front tires. I'll be posting a parting out add once I figure out what I'm going to use on my real 1972 GTX.
Yep, Not a bad looking donor but as you posted it sounds like it needs a lot and its interesting that someone put the hood from a 74 Roadrunner on it.
What kind of Weiand intake does it have? For a B engine too and do you want to sell it?
im thinking about using the Weiland and selling the Performer RPM I picked up. I think the Weiland will fit under my hood. If I decide to get rid of the Weiland I'll give Cranky first shot and a killer deal.
1st thing to do is pull off a wheel and see if there is any #'s or names on the inside of em.
