Great work and it's exciting to watch this come together!  Keep up the good work!
Hawk
			Hawk
Forgot about the two pan-head screws, run into the welded nuts...been a handful of years, since I've done mine. But, here's what it looks like...
Hawk
Only guessing, since it's been awhile, but off the two tabs on my bracket, pretty sure four in all cables were clamped to it. P brake, speedo, and both shift cables, just using two clamps back to back on each tab. Just so the picture is clear. I'm now using shift linkage.That's a good idea clipping the cables to the bracket.
When I rebuilt my blower motor (exact same one) I drilled a small hole in the bottom bearing cavity so I can lube it without disassembly. Hole is plugged with some rtv until needed. Mine was squealing pretty good before hand.
