4mulas
- 5:28 AM
- Mar 16, 2017
- Just North of Great Falls
I’ve seen calculators online but not sure if I’m using them right. Can someone help out with figuring the compression ratio for me?
The info:
-383 .020 over, so 4.27 bore
-Pistons sit .037 down in the hole
-Using felpro head gaskets (blue ones in the mopar engine tear down kits) which I think are known to be .044 or maybe .039 (somewhere in that range)
-Piston are neither domed nor dished. Flat top I suppose. Just an elcheapador cast piston like silvolite maybe or equivalent.
-Using a 516 closed chamber head with the exhaust valves enlarged to 1.74. (not sure if changing the valves reduces affects the chamber volume)
-I have 452 heads as well in case i should save the 516’s for a future 440 build??? Ie, if the gains aren’t worth using the 516’s I could swap in 452’s
As an aside I have 2 choices of cams. Which one would yah use?
-New no name Elgin style white box cam .444 214 duration@.050 intake, and .467 224 duration@.050 exhaust with 112cl OR:
-A used comp 270H which is .470 lift and 224 duration@.050 on both intake and exhaust with 110 cl
Holley street dominator intake
Car has power brakes.
Notes: I have all this crap sitting around and am just putting something together on the cheap to get rolling while I carefully think out a 440 build, so please don’t tell me such and such is crap or you wouldn’t do that etc….
I have the SA Gear double roller timing set pictured, not sure if advancing or retarding with cam is recommended by you guru’s? Or just straight up. I think the choices are 4 degrees either way. Or do I just have to degree it to see where it’s at?
Thank you in advance !
The info:
