Car pics...some questions.
dam130af
12:18 AM
Nebraska
Here is a picture of my '72 Charger. I've been meaning to post it for quite a while now. A few specs on it. I've had it about 10 years now. I bought it when I was 18 stationed at Little Rock AFB. I'm not sure on exact engine specs since I've never rebuilt it. I will add what I know.
-400 stroker Chrylser block
-Ross Ultralite Aluminum Pistons
-292/501 Comp Cam
-2.14/1.81 valves
-open port heads
-crank turned .010--.010
-2500 stall converter
-4.56 rear gears
-275/60R/15 BF Goodrich Drag Radial
-hooker headers (Jet Hot coated)
-Edelbrock 1406 carb
- MSD 6AL/Taylor wires/ Mopar Performance P3690431 Vacuum Advance Distributor
-MGK sparkplugs with .035 gap
- Usually a 104 octane boost or at least premium 93 octane gas
-727 3 speed auto w/ manual valve body trans rebuilt by J.W. Performance after gov blew hole in tail shaft
-JW Auto trans racing fluid
-Master Overhaul Kit w/ Intermediate Power Pack
-Street/Strip Performance Kit
-Spring/Roller Kit
-Reverse Servo Springs
-Stainless Pump Rings
-Wide Drum Bushing
-Output Shaft Washer/Bronze
-FWD manual valve body
-deep alum pan
-Full round wheel flex plate
-TCI transmission cooler Coil size: 3/4''h x 7-1/2''w x 12-1/2''l.
Problems I'm having right now:
-Won't start driving out in low gear until trans hits 150 degrees/ I put it in 1st gear but it stays in second/shifts into 3rd fine/ works normal after hitting 150 degrees even if it falls below 150 degrees. Just needs to hit that hot once per day.
- Mild pinging in second gear when going up slight inclines
- Almost dies when you barely push gas pedal down then suddenly takes off
- At idle the ammeter fluxes from neutral to Charge/I can hear the fuel pump with the same wavering tone. Not sure if it is cam idle or what.
-When I get on it seems like there is oil coming from the round chrome breather on the RH valve cover. There's a hot oil burning smell. Not sure if it is running on the header from there or not.
I'm still learning so if you can think of anything for these problems or if you see anything in the picks that should be adjusted fixed let me know. I just finished putting the Sidewinder shifter, new carpet, and repainting all the side panels in interior. Thanks for any help.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
welcome to fbbo
Welcome....All those issues could be an assortment of different things. Bad accelerator pump? Timing off? Improper Linkage connection? Bad tranny? Best bet would be to post the questions in the appropriate subject matters. Sorry to say but not everyone gets a chance to visit the welcome wagon on a frequent basis and you may find people more apt to answer your questions there.
Welcome aboard the forum!
