David
Was drving the other day and noticed my idle was very low (300 rpm) So in the process of returning home the car died 3 times and was kind of stumbling on acceleration from stop. Noticed that idle would stay around 300 rpm when i started it so i turned up the idle. My normal idle in park is around 900 rpm. THe next day went to start it and was idleing around 1200 rpm thought this solved the problem. But as soon as i drop the car in to gear and give it some gas the idle drops down again and the car dies. Then if I go to start it after that it won't stay running. Noticed that the float levels are low. Not sure what is goin on. Its a 71 charger 318 auto with this 600cfm carb (SUM-M08600VS) and this manifold (SUM-226040)
