Carter 4640 AVS Questions
DieselPower
6:42 PM
Deer Creek, IL
4640SA Carter AVS, 1976 date code
I got this carb off if eBay years ago knowing I would be rebuilding it. It looked like it was never taken apart, but now I'm not so sure.
3 questions:
1 - There was no spring behind the fuel strainer behind the inlet fitting. Normal, or did they all have one?
2 - There is a slot for a baffle in each bowl, but only the side nearest the inlet (passenger) had a baffle. I couldn't see any witness marks where a baffle might have been on the driver side. Should both sides have one?
3 - The secondary jets are the same size as the factory (.095"). The primaries are also .095", but are the short jet with 2 step rods. I was under the impression that this carb would have had the tall jets with 3 step rods. It's still has the dimpled piston/rod covers and not the flat ones. Thoughts?
Thanks guys!
3 questions:
Thanks guys!
I have a few, I’ll look
1. I cannot say the spring behind the strainer is all that common. I've only seen one once or twice in 30 assorted AVS rebuilds.
2. yes, both sides normally have the slid in baffle. but some don't have any.
3. according to my data, the 4640 primary jets are .101, and the three stage metering rods measure 0.065 x 0.062 x 0.053
Yep, those are the specs my 69 service manual give. I see some NOS tall jets out there that size, but haven't found any 3 step metering rods yet. You guys think someone switched jets and rods and just forgot or didn't know to swap the cover?
The engine is pretty stock except for Stealth Heads and a Mr. Six Pack cam. I'll have to figure out a good starting point.
Should I find a baffle? Are these carbs prone to fuel sloshing around and having fuel starvation issues?
Good to know about the filter spring.
Thanks!
3 questions:
1 - There was no spring behind the fuel strainer behind the inlet fitting. Normal, or did they all have one? Strainer fits in the recess of the inlet fitting.
2 - There is a slot for a baffle in each bowl, but only the side nearest the inlet (passenger) had a baffle. I couldn't see any witness marks where a baffle might have been on the driver side. Should both sides have one? Yes
I don't recall a "square jetted" AVS.
Thanks guys!
Mike
I ran a 4640 on my 383/432 Stroker for awhile with Edelbrock Heads and Intake
Unless it’s OEM Gold standard points your looking for , I wouldn’t waste time trying to find Tall primary jets and three step metering rods
You can fill in the factory metering rod covers with JB Weld and smooth them out or make your own flat metering rod covers out of aluminum
Does it have the hot idle compensator - I just replaced the factory gasket with one I made without the hole in the middle of the gasket and reinstalled the compensator
.101 Edelbrock Primary Jets - 65 / 52 Metering rods I started with
Pink Edelbrock Metering Rod Springs
.104 Edelbrock Secondary Jets
Drilled out the idle tubes to .037
Red accelerator pump
Carb was flawless , perfect , right up until I sold it to friend LOL
Honestly wish I still had it
Plugs with that same carb 383/432
Great info! Thank you.
I have read where others had good luck with the three step rods since it gave smoother transitions from light to heavy throttle. That's really the only reason I would go back to that style. That and I would have a good starting point for tuning.
What cam were you running?
It does have the hot idle compensator.
