SOLD Cast 440 crank ground 10/10 440 30 over pistons and rods Crower cam
wannadrag
5:02 AM
Waupaca WI
Feedback: +5 / =0 / -0
I have a nice cast 440 crank ground at 10/10.It has very low miles,i took it in to get polished and they told me it was a waste it looked so good yet. The bearings are nice yet and will go with it $200.00
Also have a set of 8 used rods and pistons from the same engine.The pistons are a cast 30 over and I cant find any markings on them other than the 30 on top.Bearings are still on the rods and rings on the pistons and I have no doubt you could use them as they have no wear. $150.00
And I also have a used Crower hyd 500 lift cam with a set of used comp cam springs to go with it.I checked all the lobes and there is no difference in any of them.$150.00
If someone wanted everything I could do better on the price
Trade for a good 28 spline Ford 9" center with some 411 or 456 gears
I might be interested in those pistons. I'm having trouble finding any information based on 916P. I don't suppose you know any of the specs on them, do you??? If so, thanks!
I cant find anything on the number either.But it seems to be a old speedpro/federal mogul number
