747mopar
When they tested the water prior to this job I had them test the existing cistern and the overflow which had the 2nd spring already plumbed in so yes it was already tested. This was a generic test that only tested PH, Iron, Calcium, Hardness and TDS, it tested well... better than most wells and definitely better than city water. The test as far as cleanliness goes isn't an accurate assessment since it doesn't account for the sediment kicked up by hard rains.Have you had the water from the new system tested yet and are you planning on monitoring the system threw weather cycles.
