Connecting main harness to console wiring
dodge68charger
3:57 PM
Washington
How does the main wiring harness connect to the 4 speed console wiring harness on a 68 b body. I cant find any wiring harnesses in the classic industries catalog. There is a connector on the main harness that plugs into the console wiring harness but it seems like it needs to be extended 3 feet. Thanks
nobody reproduces it that I know of...the console harness just plugs into the body harness of the car. Auto console harness can be made into a 4spd harness with little work. I have done it in the past
I gotta jump in here real fast. First off a quick question...Do you have a color schematic for the wiring of your charger? If not then get one as it is an invaluable tool in helping you to decipher your wiring situation. Use it along with a FSM...Factory Service Manual....you do have one right? These 2 tools always have what you need to get the wiring down right. I do not know how many times the same topics come up concerning wiring and the Poster doesn't have either of these tools. You can never have enough tools now right. Here is a couple of links for you. They aren't cheap but well worth the expense. Good luck though if you are still going to mudder along without hem...cr8crshr/Tuck
http://www.mymopar.com/index.php
I bought my color coded wiring schematic off E-bay for my '70 Bee. I can't remember the name of the seller, but if you go to E-bay and do a search it will be very easy to find. It is color coded, clear plastic coated and I believe 11"x17" custom made for exact car with options. It is a very nice piece and easy to follow. It cost me about $20 if I remember correctly. This with the FSM are 2 tools that have helped me over and over.
