Cool that carb...
runner74
8:01 AM
MA
Could anyone recommend the best carb spacer to keep the carb cooler?
Stock 400 cubes with 4 barrel carter AFB (9636A 1707), hp manifolds.
Suspect fuel boiling off when shut down hot can be a little hard to start when still hot.
1/2 inch phenolic. Spelling? Move and wrap fuel lines. Use your favorite ethanol-fighter, min is Amsoil 100:1 marine. An ounce per tank.
I ran a -6 AN line from the Carter fuel pump in insulation wrap away from the block and over by the inner fender well and a phenolic spacer to keep the fuel from boiling in a 69 Daytona to lessen that issue in southern california heat.
