Cam Style:Mechanical roller tappet
Basic Operating RPM Range:3,750-7,750
Intake Duration at 050 inch Lift:262
Exhaust Duration at 050 inch Lift:268
Duration at 050 inch Lift:262 int./268 exh.
Advertised Intake Duration:304
Advertised Exhaust Duration:310
Advertised Duration:304 int./310 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.650 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.624 in.
Valve Lift with Factory Rocker Arm Ratio:0.650 int./0.624 exh.
Lobe Separation (degrees):106
Intake Valve Lash:0.026 in.
Exhaust Valve Lash:0.028 in.
