biomedtechguy
Accelerati Rapidus Maximus
- 5:54 AM
- Mar 28, 2014
- South Louisiana
Thanks for all of the help and support of my various posts and questions and comments about the 6bbl RB stroker motor I have "planned" for at least a year.
Jim LaRoy was my choice for the build, and I appreciate his continued support, and his reasons for not taking any new builds.
What I am asking for now is opinions or advice on a new perspective for power under my hood.
Instead of starting with a RB block that my builder or I would find and supply (because I was going to just fog and wrap my current motor, using only the 6bbl intake, carbs, and headers off of it) and build a stroker, topped with my 3 Holley 2bbl carbs and aluminum intake, looking for as close to 600 HP and at least 650 Ft Lbs torque, and Trick Flow 240s....
Instead, would it make more sense and cost a significantly less amount of money to use my existing 71 440 steel crank heavy rods motor, do a clean up or slight bore of it since I would have to change the pistons anyway, maybe change the heavy stock rods to something stronger and lighter too, and still get the TF 240s. Also maybe change out what I believe is the Mopar purple stripe 292°/.509 cam and change that while the engine is being worked on? The way I would get the power (6XX HP and Torque) would be via a Nitrous Express SAFE 1 gal aux tank and pump:
https://www.nitrousexpress.com/1500...mp-5-12psi-adjustable-regulator-gasoline.html
and their 2bbl nitrous plate system (I already have the center spray plate) that is rated for 50-300 horsepower.
https://www.nitrousexpress.com/30026-10-holley-2-bbl-tri-power-3-plates-gasoline-50-300hp.html
I would guess that the refreshed 440 with the TF 240s would probably be around 475 Horsepower easily, so add 150 to that and I'm at 625 HP without a dangerous amount of nitrous (125 HP shot). I could probably push the nitrous to 150 and still be really safe regarding no real chance of engine failure.
Since I rarely go to the race track, and when I do it's for test and tune or racing friends or maybe someone I run across at the track, the biggest question is how much less the nitrous route would cost vs the stroker, and I don't want to have problems or tear it down for maintenance or repairs once I get it built.
Total cost for the SAFE tank and Nitrous system together is about $1,500
Thanks.
Thanks.
Between the parts and labor, the 421 rebuild was around $8k that included a 2nd shop pulling the engine and reinstalling it. I had the Muncie 4 speed resealed, and the Quick Performance, UMI, and Wilwood parts and labor last September cost around $5k off the top of my head...
