Custom pistons ?
There are some new pistons/rings on ebay. Std and oversizes...
https://www.ebay.com/itm/Pistons-Ri...214a9e6253:g:PBcAAOxyXWdQ7-Xc&redirect=mobile
Also there was 5 std pistons from another seller if you do a search.
I would need to take the pan off and pop the pistons out on the 361we have to check them out, I would think they would be ok....it did run once upon a time it ran fine it was replaced by a 383.
Thanks I'll double check ebay again.
Only if you want to, that would be great.
If you are interested in those ebay pistons, I urge you to message the lister on their availability and sizes before you do anything else. I was trying to quote a Ford 262 6cyl, and pistons of ALL sizes were made from "unobtanium", until I came across an ebay listing. I found their external info, and called, called, emailed, but no response. I won't say it was the same people as this listing, but it sure looks the same to me, and vaguely remember them from NJ too. If "Curious" will supply his, I think you would be better off, unless the ebay listing is valid.
69 Bee , Thank you, I think Curious member is gonna fix me up with what I need !
This is what makes this site so cool !
If anyone is still looking for replacement 361 Wedge pistons, you can contact me and I can check our stock. Please don't forget that we also carry rod & main bearings, engine gasket sets and other replacement engine parts and some rebuilding services
Mike @ Egge
Sales Manager
20220509_113235.jpg 20220506_074441.jpg 20220506_165531.jpg 20220429_170805.jpg 20220511_134130.jpg 20220510_135432.jpg 20220510_135413.jpg
Personally I'd look for a 383 short block. Tell everyone it's a 361 and be done. It'll be cheaper in the long run.
Doug
