Idk what it's worth to be honest, and I do have a person that said he'd do a grand, but he's a month or 2 out for getting money. He said its worth to him 800-1500$ depends on condition. I know the block is worth a lot more to a restorer than it is to me, so if someone wants it and is willing to pay is it not worth it? I never got the whole casting date and HP stamp craze but some do i guess. If could horse trade into a honeable standard bore block I'd rather do that as I already have a rotating assembly with l2295fs from another guy. If I bore over its waiting a lot of time and another 1k for machine work, then I need to drop 500$ on pistons, 150$ on rings, then spend another 500$ for balance and probably another 75$ or so for pressing the pistonsIn Less than 1 hour you post it forsale for $1200?
If he is willing to pay the money, I would say grab it.Idk what it's worth to be honest, and I do have a person that said he'd do a grand, but he's a month or 2 out for getting money. I know the block is worth a lot more to a restorer than it is to me, so if someone wants it and is willing to pay is it not worth it?
That's where I am with the situationIf he is willing to pay the money, I would say grab it.
Yeah, I just can't find those, I dont know if Hawaii is isolated from the rest of the country but I can't find a rebuildable forged crank with decent heads for under at least 1500$, and that's a block that is seizedI'm not a numbers type of guy. Unless it has the my vin stamped on it then to me it's just another 440 block. It's a little harder now a days, but I can still find a complete 440 with all the accessories for 500-700 as a core to rebuild
www.forbbodiesonly.com
I honestly never even saw his posts before, I dont know how my searches are filtered by the search engine here, so it is a crap shoot as for what I see even if I only search in the want to sell forums. I base my prices and "value" on a lot of the parts and everything on the FB marketplace crapshootWhy don't you try randys4406? He's a longtime member and seems to have a few engines for sale. Only 120 miles away from you.
You are doing things in the worse possible way. Buying parts in a shotgun pattern will cost you more in the end. You start with a block and get the right piston size and go from there.I honestly never even saw his posts before, I dont know how my searches are filtered by the search engine here, so it is a crap shoot as for what I see even if I only search in the want to sell forums.
On another note I picked up a polished 440 forged crank, resized and new rod bolts bushed for a floating 1.094 pin ly rods with l2295fs and NOS mopar "premium" ductile iron rings. The rotating assembly's balanced and I got it with a distributor drive shaft and a 1990 MP catalog for 580$. Now i either gotta get new pistons or find just ANOTHER block
But then I have to pay twice over on machining costs when I buy everything else piecemeal, no? At least with this i can just get the 30 over piston and they're close on weight instead of having to resize rods and polish the crank and balance. I quoted a couple machine shops, all in on the rotating assembly I was at least 1300$ in on laborYou are doing things in the worse possible way. Buying parts in a shotgun pattern will cost you more in the end. You start with a block and get the right piston size and go from there.
No you will not pay a machine shop twice. But the way you are going you will pay twice.But then I have to pay twice over on machining costs when I buy everything else piecemeal, no? At least with this i can just get the 30 over piston and they're close on weight instead of having to resize rods and polish the crank and balance. I quoted a couple machine shops, all in on the rotating assembly I was at least 1300$ in on labor
As for the shotgun pattern, yeah, it is inefficient but some day ill find use for it all, still got a lot of life ahead of me, im 17 not 70
As far as being 17 and not 70 tells me you have a lot of time to be stupid. Don't take it in a bad way. The fact is one day when you reflect on the decisions you made you will say boy was I stupid. Why did I not listen.But then I have to pay twice over on machining costs when I buy everything else piecemeal, no? At least with this i can just get the 30 over piston and they're close on weight instead of having to resize rods and polish the crank and balance. I quoted a couple machine shops, all in on the rotating assembly I was at least 1300$ in on labor
Lmk if I'm thinking about this wrong
………If could horse trade into a honeable standard bore block I'd rather do that as I already have a rotating assembly with l2295fs from another guy.
Its been mentioned by previous post that there is a tool used to remove the ridge above the top ring. It is a bit of a lost art..most people just go oversize and don't bother.So, finally got to honing a cylinder on this 440 block to examine condition through all the surface rust. Can't get some of this rust, and looks as if there's a very noticeable ridge a little down a 1/4 inch from the deck. Assuming this needs to go to machine shop? Mostly worries about rings not seating, but if they will I'll send it.View attachment 1866032
Yes, they're standard bore 2295s that are floating in the rods instead of pressed, as they can do both i think. I do have the 1/16 rings too Used pb blaster when honed, what i had at the time to do just one cylinder. Kept spraying it as I went with drill. Now that I researched more on it apparently atf is a better lubricant for it.Its been mentioned by previous post that there is a tool used to remove the ridge above the top ring. It is a bit of a lost art..most people just go oversize and don't bother.
When you honed what oil or lubricant did you use?
Are the 2295 pistons standard? Are they rings you picked up 1/16"? That is the width of the compression rings of a 2295. Oem was 5/64 in a 69 440hp.
It takes time time to remove the ridge. Been years since I used the tool, IMHO...it is the only shot of honing it yourself. Remove the ridge so hone makes contact.Yes, they're standard bore 2295s that are floating in the rods instead of pressed, as they can do both i think. I do have the 1/16 rings too Used pb blaster when honed, what i had at the time to do just one cylinder. Kept spraying it as I went with drill. Now that I researched more on it apparently atf is a better lubricant for it.
Now, why do people hate the ridge reamer, and what do you think about what they say for it?
