Dash color
Data Plate
12:17 AM
New York
I have my windshield out and I’d like to repaint the front metal part of the dash what’s the correct color to use?
Is this question for real?
You may need to help us out a bit, my crystal ball is out of service today.
From the factory they were painted chartreuse... LOL JK JK... are you painting the dash or something else? If it is the dash then it depends on what color the dash is.
No it isn’t satin. Go to the auto paint store and have them mix you the correct paint. They have it. It doesn’t come in a rattle can.
are you on a 69 charger for this?
Ok thanks
The dash frame top on a 69 Charger has a texture. I have replicated it twice using SEMS Texture Coating.
Are you restoring the whole dash or just this metal on top? If your pad looks crappy the paint will accentuate it. Just my opinion, I'd pull the dash and treat the whole frame. It's fun! :D
I was just doing the metal the pad is fine I’ll try the send thank for the info
So the texture coat and then semi gloss black should work well ??
