383man
Zero camber is fine for a drag car. You want some negative camber for a car that will be street driven if you want a little better handling and even tire wear.
No actually my 63 calls for 1/4 to 1/2 positive camber by the factory specs. But like I say I like to set them right at zero and I have had my 63 on the road with them settings since 2006. I still have the same front tires on it with no uneven wear as they are wearing perfectly and it handles nicely for a 1963 car. Now if I had a car that calls for negative camber then I may set it different as I like to see what the factory specs are first when the car has a stock front end and then work from there. Ron
