Different ways to pull the engine
Caught yourself a trophy Marlin?
almost
I like runcharger’s point view.
The idea of doing production line style just like Chrysler did is sexy but I personally don’t want to store some get up for holding the engine and trans combo, I don’t have a car hoist, and then you need a ton of room in the garage for the engine hoist or what ever you use to lift the car.
When I do it I just pull it from the top. I use this: Mac's Custom Tie-Downs 701001 Mac's Engine Pivot Plates | Summit Racing
Which makes life easy.
I've removed and replaced big blocks with transmissions attached in no time at all. You don’t need a second set of hands either so organizing a buddy to come over and waiting in their schedule doesn’t come I to play. It literally takes me 5-10 minutes to remove once the hoses, mounts, and exhaust etc is all in hooked. Maybe 15 minutes going in just to be extra careful.
Mine was easy. Some 2" .060 square, a piece of 3/16" for the trans pan with a couple of scraps on the sides for a fence, 3 swivel casters rated at 350lbs each. In the future, I'll put a scissors jack in there for the trans portion. Help with the leveling.
If a Carpenter can figure this out....
....then anyone can do it.
Going back in after the rebuild.....
19 minutes to install...
I removed the engine and trans the same way at my buddy's shop about 10 years ago now using the same method. Cliff's young apprentice was impressed with how quick I did the job single-handed using their spare hoist. He told me I did well for an Electrician.
I just took my time and did the job methodically....no mess no fuss..... unlike the grease-monkeys on Rust Bros.
If you sit on your hand for a minute and let it numb up a bit it'll feel like someone else's...oh wait dangit I thought this was about different ways to pull something else...wrong forum sorry
:lol: :lol: :rolleyes: :rolleyes:
Did a compression check on my 1969 Road Runner engine yesterday. Got 1,3,5,2, 135 psi-4,6, 130 psi, and 7 125 psi, and 8 120 psi.
Readings are in spec and for an engine rebuilt over 40 years ago its held up well. However I wanted to do a few things, Aluminum DB4
intake, TTI headers, newer carb, recam it. So I'm thinking about pulling it and reringing it. Now I have a cherry picker, but I also have a
lift. I was thinking instead of pulling the engine out of the car, pulling the torsion bars, upper control arms, and unbolting the K frame and
lifting the car up. Never done it that way but it seems to be a cleaner way of doing it. I was looking for feedback on folks who have done
the K frame method ?
I purchased a stand just for that(engine and K frame) from Mancini (I think). Not cheap and there are other ways to make them etc but I don't have the time. Anyway, I have a lift and with this it is super easy to remove the engine, work on it, etc. I will put it all together with front end etc as much as possible before I re-install. I took it our entirely by myself, it is that easy with the appropriate stand, lift etc. I'll try to post pics later....
One thing I need to change on mine. Put a scissors jack at the trans post.
I know guys love to spend money but I like to spend it on car parts or tools I'll use every day. When I do go from underneath, I set the engine/trans on a few car skates or carpenter up something out of wood. I lower the body down using the engine hoist and support it on jack stands, then lift up the engine/trans assembly with the hoist.
Then you can put the car skates under a car again or knock down the wooden frame and use the wood for something else. I always work alone and have done this more than once with no hassle.
I will say putting everything from the bottom in the garage was pretty easy, I built the usual cart, a lifting bar for the front of the car and then did a quick weight check just for kicks (259kg = only 507lbs!). All of this was done with the car backed into my garage, once the front of the car was up I slid the powertrain in from the side. Due to some issues with the bellhousing I had it in and out 4 times, 2 of them were by myself.
Finally done with the dolly, also painted my 41 year old engine stand and added a turn handle. Actually getting excited about this. I haven't had a B engine apart since 1990. The one in the Road Runner was rebuilt in the 1980s. A lot has changed since then, especially me. I did add a couple of pieces of plate steel I hand laying around and bolted it to the T because I haven't welded in years and don't completely trust my welds there, insurance. Also added gussets to the posts.
